IO.StartOffline
IO.StartOffline
Boolean Configure to True to start a Driver in Offline mode and to False to start a Driver in Online mode.
NOTE
It is pointless to change this property at run time, as it can only be changed when a Driver is already in Offline mode. To configure a Driver in Online mode at run time, write the value 1 (one) to the IO.WorkOnline Tag.
