IO.IOKitEvent
IO.IOKitEvent
Type of Tag
Block Tag
Type of Access
Read-Only
B1 Parameter
-1 (minus one)
B2 Parameter
0 (zero)
B3 Parameter
0 (zero)
B4 Parameter
1 (one)
Size Property
4 (four)
ParamItem Property
IO.IOKitEvent
This Block returns Driver events generated by several sources in I/O Interfaces. The TimeStamp property of this Block represents the moment this event occurred. The Block Elements are the following:
Element 0: Type of event. Possible values are 0: Information, 1: Warning, or 2: Error
Element 1: Source of event. Possible values are 0: Driver (specific of a Driver), -1: IOKit (generic events of I/O Interfaces), -2: Serial Interface, -3: Modem Interface, -4: Ethernet Interface, or -5: RAS Interface
Element 2: Error number, specific for each source of event
Element 3: Event message, a String specific for each event
NOTE
A Driver keeps a maximum number of 100 events internally. If additional events are reported, older events are discarded.
