I/O Tags
I/O Tags
Tags of an Ethernet Interface (N2/B2 = 4)
The Tags described next allow controlling and identifying an Ethernet Interface at run time and they are also valid when the RAS Interface is selected.
IMPORTANT
These Tags are available ONLY while a Driver is in Online mode.
The available Tags on this section are the following:
IO.Ethernet.IPSelect
IO.Ethernet.IPSwitch
