Driver Settings |
The [P] parameters for this Driver configuration are not used. The BCM BCM1_MasterSlave Driver was developed using Elipse Software's IOKit library. This library, after configured by the user, is responsible for implementing the physical layer access, Serial, Ethernet, Modem, or RAS.
All IOKit- and Driver-specific configurations must be performed on the properties window of this Driver or using the Extra Settings option in Elipse SCADA.
In this properties window, the BCM1_MasterSlave tab contains specific settings for this Driver. All other tabs refer to communication settings of Elipse Software's IOKit library.
For more information about the configuration of IOKit library, please check topic Documentation of I/O Interfaces.
