IO.Serial.DelayAfterMs |
Number of milliseconds to delay after the last byte is sent through a serial port, but before turning the RTS signal off. Available only when the IO.Serial.RTS property is configured with the value Toggle and the IO.Serial.WaitCTS property is configured to False.
