Error_ErrorCode |
<xs:simpleType name="Error_ErrorCode">
<xs:enumeration value="other" />
<xs:enumeration value="configurationInProgress" />
<xs:enumeration value="deviceBusy" />
<xs:enumeration value="dynamicCreationNotSupported" />
<xs:enumeration value="fileAccessDenied" />
<xs:enumeration value="inconsistentParameters" />
<xs:enumeration value="inconsistentSelectionCriterion" />
<xs:enumeration value="invalidDataType" />
<xs:enumeration value="invalidFileAccessMethod" />
<xs:enumeration value="invalidFileStartPosition" />
<xs:enumeration value="invalidParameterDataType" />
<xs:enumeration value="invalidTimestamp" />
<xs:enumeration value="missingRequiredParameter" />
<xs:enumeration value="noObjectsOfSpecifiedType" />
<xs:enumeration value="noSpaceForObject" />
<xs:enumeration value="noSpaceToAddListElement" />
<xs:enumeration value="noSpaceToWriteProperty" />
<xs:enumeration value="noVtSessionsAvailable" />
<xs:enumeration value="propertyIsNotAList" />
<xs:enumeration value="objectDeletionNotPermitted" />
<xs:enumeration value="objectIdentifierAlreadyExists" />
<xs:enumeration value="operationalProblem" />
<xs:enumeration value="passwordFailure" />
<xs:enumeration value="readAccessDenied" />
<xs:enumeration value="serviceRequestDenied" />
<xs:enumeration value="timeout" />
<xs:enumeration value="unknownObject" />
<xs:enumeration value="unknownProperty" />
<xs:enumeration value="unknownVtClass" />
<xs:enumeration value="unknownVtSession" />
<xs:enumeration value="unsupportedObjectType" />
<xs:enumeration value="valueOutOfRange" />
<xs:enumeration value="vtSessionAlreadyClosed" />
<xs:enumeration value="vtSessionTerminationFailure" />
<xs:enumeration value="writeAccessDenied" />
<xs:enumeration value="characterSetNotSupported" />
<xs:enumeration value="invalidArrayIndex" />
<xs:enumeration value="covSubscriptionFailed" />
<xs:enumeration value="notCovProperty" />
<xs:enumeration value="optionalFunctionalityNotSupported" />
<xs:enumeration value="invalidConfigurationData" />
<xs:enumeration value="datatypeNotSupported" />
<xs:enumeration value="duplicateName" />
<xs:enumeration value="duplicateObjectId" />
<xs:enumeration value="propertyIsNotAnArray" />
<xs:enumeration value="abortBufferOverflow" />
<xs:enumeration value="abortInvalidApduInThisState" />
<xs:enumeration value="abortPreemptedByHigherPriorityTask" />
<xs:enumeration value="abortSegmentationNotSupported" />
<xs:enumeration value="abortProprietary" />
<xs:enumeration value="abortOther" />
<xs:enumeration value="invalidTag" />
<xs:enumeration value="networkDown" />
<xs:enumeration value="rejectBufferOverflow" />
<xs:enumeration value="rejectInconsistentParameters" />
<xs:enumeration value="rejectInvalidParameterDataType" />
<xs:enumeration value="rejectInvalidTag" />
<xs:enumeration value="rejectMissingRequiredParameter" />
<xs:enumeration value="rejectParameterOutOfRange" />
<xs:enumeration value="rejectTooManyArguments" />
<xs:enumeration value="rejectUndefinedEnumeration" />
<xs:enumeration value="rejectUnrecognizedService" />
<xs:enumeration value="rejectProprietary" />
<xs:enumeration value="rejectOther" />
<xs:enumeration value="unknownDevice" />
<xs:enumeration value="unknownRoute" />
<xs:enumeration value="valueNotInitialized" />
<xs:enumeration value="invalidEventState" />
<xs:enumeration value="noAlarmConfigured" />
<xs:enumeration value="logBufferFull" />
<xs:enumeration value="loggedValuePurged" />
<xs:enumeration value="noPropertySpecified" />
<xs:enumeration value="notConfiguredForTriggeredLogging" />
<xs:enumeration value="unknownSubscription" />
<xs:enumeration value="parameterOutOfRange" />
<xs:enumeration value="listElementNotFound" />
<xs:enumeration value="busy" />
<xs:enumeration value="communicationDisabled" />
<xs:enumeration value="success" />
<xs:enumeration value="accessDenied" />
<xs:enumeration value="badDestinationAddress" />
<xs:enumeration value="badDestinationDeviceId" />
<xs:enumeration value="badSignature" />
<xs:enumeration value="badSourceAddress" />
<xs:enumeration value="badTimestamp" />
<xs:enumeration value="cannotUseKey" />
<xs:enumeration value="cannotVerifyMessageId" />
<xs:enumeration value="correctKeyRevision" />
<xs:enumeration value="destinationDeviceIdRequired" />
<xs:enumeration value="duplicateMessage" />
<xs:enumeration value="encryptionNotConfigured" />
<xs:enumeration value="encryptionRequired" />
<xs:enumeration value="incorrectKey" />
<xs:enumeration value="invalidKeyData" />
<xs:enumeration value="keyUpdateInProgress" />
<xs:enumeration value="malformedMessage" />
<xs:enumeration value="notKeyServer" />
<xs:enumeration value="securityNotConfigured" />
<xs:enumeration value="sourceSecurityRequired" />
<xs:enumeration value="tooManyKeys" />
<xs:enumeration value="unknownAuthenticationType" />
<xs:enumeration value="unknownKey" />
<xs:enumeration value="unknownKeyRevision" />
<xs:enumeration value="unknownSourceMessage" />
<xs:enumeration value="notRouterToDnet" />
<xs:enumeration value="routerBusy" />
<xs:enumeration value="unknownNetworkMessage" />
<xs:enumeration value="messageTooLong" />
<xs:enumeration value="securityError" />
<xs:enumeration value="addressingError" />
<xs:enumeration value="writeBdtFailed" />
<xs:enumeration value="readBdtFailed" />
<xs:enumeration value="registerForeignDeviceFailed" />
<xs:enumeration value="readFdtFailed" />
<xs:enumeration value="deleteFdtEntryFailed" />
<xs:enumeration value="distributeBroadcastFailed" />
<xs:enumeration value="unknownFileSize" />
<xs:enumeration value="abortApduTooLong" />
<xs:enumeration value="abortApplicationExceededReplyTime" />
<xs:enumeration value="abortOutOfResources" />
<xs:enumeration value="abortTsmTimeout" />
<xs:enumeration value="abortWindowSizeOutOfRange" />
<xs:enumeration value="fileFull" />
<xs:enumeration value="inconsistentConfiguration" />
<xs:enumeration value="inconsistentObjectType" />
<xs:enumeration value="internalError" />
<xs:enumeration value="notConfigured" />
<xs:enumeration value="outOfMemory" />
<xs:enumeration value="valueTooLong" />
<xs:enumeration value="abortInsufficientSecurity" />
<xs:enumeration value="abortSecurityError" />
<xs:enumeration value="duplicateEntry" />
<xs:enumeration value="invalidValueInThisState" />
</xs:restriction>
</xs:simpleType>
Example 1:
<Error_ErrorCode>other</Error_ErrorCode>
