BACnetStatusFlags |
<xs:complexType name="BACnetStatusFlags">
<xs:sequence>
<xs:element minOccurs="0" maxOccurs="1" name="inAlarm" type="Boolean" />
<xs:element minOccurs="0" maxOccurs="1" name="fault" type="Boolean" />
<xs:element minOccurs="0" maxOccurs="1" name="overridden" type="Boolean" />
<xs:element minOccurs="0" maxOccurs="1" name="outOfService" type="Boolean" />
</xs:sequence>
</xs:complexType>
Example 1:
<BACnetStatusFlags>
<inAlarm>true</inAlarm>
<overridden>true</overridden>
</BACnetStatusFlags>
