BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications |
<xs:complexType name="BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications">
<xs:sequence>
<xs:element minOccurs="0" maxOccurs="unbounded" name="ListOfCovSubscriptionSpecifications_Item" type="BACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications_Item" />
</xs:sequence>
</xs:complexType>
Example 1:
<SequenceOfBACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications />
Example 2:
<SequenceOfBACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications>
<ListOfCovSubscriptionSpecifications />
<ListOfCovSubscriptionSpecifications>
<ListOfCovSubscriptionSpecifications_Item>
<MonitoredObjectIdentifier>device-501</MonitoredObjectIdentifier>
<ListOfCovReferences>
<ListOfCovReferences_Item>
<MonitoredProperty>
<PropertyIdentifier>ackRequired</PropertyIdentifier>
<PropertyArrayIndex>1236</PropertyArrayIndex>
</MonitoredProperty>
<CovIncrement>1237.567749</CovIncrement>
<Timestamped>true</Timestamped>
</ListOfCovReferences_Item>
</ListOfCovReferences>
</ListOfCovSubscriptionSpecifications_Item>
</ListOfCovSubscriptionSpecifications>
<MonitoredObjectIdentifier>device-505</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>activeVtSessions</PropertyIdentifier>
<PropertyArrayIndex>1240</PropertyArrayIndex>
<CovIncrement>1241.567749</CovIncrement>
</SequenceOfBACnetCOVMultipleSubscription_ListOfCovSubscriptionSpecifications>
Example 3:
<MonitoredObjectIdentifier>device-509</MonitoredObjectIdentifier>
<ListOfCovReferences />
<MonitoredObjectIdentifier>device-510</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>apduSegmentTimeout</PropertyIdentifier>
<PropertyArrayIndex>1245</PropertyArrayIndex>
<CovIncrement>1246.567749</CovIncrement>
<MonitoredObjectIdentifier>device-514</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>bias</PropertyIdentifier>
<PropertyArrayIndex>1249</PropertyArrayIndex>
<CovIncrement>1250.567749</CovIncrement>
<MonitoredObjectIdentifier>device-518</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>controlledVariableReference</PropertyIdentifier>
<PropertyArrayIndex>1253</PropertyArrayIndex>
<CovIncrement>1254.567749</CovIncrement>
<MonitoredObjectIdentifier>device-522</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>dateList</PropertyIdentifier>
<PropertyArrayIndex>1257</PropertyArrayIndex>
<CovIncrement>1258.567749</CovIncrement>
Example 4:
<MonitoredObjectIdentifier>device-526</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>derivativeConstantUnits</PropertyIdentifier>
<PropertyArrayIndex>1261</PropertyArrayIndex>
<CovIncrement>1262.567749</CovIncrement>
<MonitoredProperty>
<PropertyIdentifier>deviceAddressBinding</PropertyIdentifier>
<PropertyArrayIndex>1264</PropertyArrayIndex>
<CovIncrement>1265.567749</CovIncrement>
<MonitoredProperty>
<PropertyIdentifier>elapsedActiveTime</PropertyIdentifier>
<PropertyArrayIndex>1267</PropertyArrayIndex>
<CovIncrement>1268.567749</CovIncrement>
<MonitoredObjectIdentifier>device-536</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>eventType</PropertyIdentifier>
<PropertyArrayIndex>1271</PropertyArrayIndex>
<CovIncrement>1272.567749</CovIncrement>
<MonitoredObjectIdentifier>device-540</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>fileAccessMethod</PropertyIdentifier>
<PropertyArrayIndex>1275</PropertyArrayIndex>
<CovIncrement>1276.567749</CovIncrement>
<MonitoredObjectIdentifier>device-544</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>highLimit</PropertyIdentifier>
<PropertyArrayIndex>1279</PropertyArrayIndex>
<CovIncrement>1280.567749</CovIncrement>
<MonitoredObjectIdentifier>device-548</MonitoredObjectIdentifier>
<MonitoredProperty>
<PropertyIdentifier>integralConstant</PropertyIdentifier>
<PropertyArrayIndex>1283</PropertyArrayIndex>
<CovIncrement>1284.567749</CovIncrement>
