trendLogMultiple.logInterval |
Specifies the periodic interval in hundredths of seconds for which the referenced properties are to be logged when Logging_Type has the value POLLED. If Logging_Type has the value TRIGGERED, then the value of this property shall be zero and ignored. This property shall be writable if Logging_Type has the value POLLED, and shall be read-only if Logging_Type has the value TRIGGERED.
Property logInterval of object trendLogMultiple can be read and written using a single IOTag.
trendLogMultiple-<objectAddress>.logInterval |
<type> = 27 |
<property> = 134 |
A 32-bit unsigned integer.
