trendLogMultiple.logDeviceObjectProperty |
Specifies the properties to be logged.
Property logDeviceObjectProperty of object trendLogMultiple can be read and written using a single IOTag.
trendLogMultiple-<objectAddress>.logDeviceObjectProperty |
<type> = 27 |
<property> = 132 |
A character string containing an XML with a value of type <SequenceOfBACnetDeviceObjectPropertyReference>.
