trendLogMultiple.intervalOffset |
Specifies the offset in minutes from the beginning of the period specified for time synchronization until the actual time synchronization requests are sent.
Property intervalOffset of object trendLogMultiple can be read and written using a single IOTag.
trendLogMultiple-<objectAddress>.intervalOffset |
<type> = 27 |
<property> = 195 |
A 32-bit unsigned integer.
