trendLogMultiple.eventMessageTextsConfig |
Contains the character strings which are the basis for the 'Message Text' parameter for the event notifications of TO_OFFNORMAL, TO_FAULT, and TO_NORMAL events, respectively, generated by this object. The character strings may optionally contain proprietary text substitution codes to incorporate dynamic information such as date and time or other information.
Property eventMessageTextsConfig of object trendLogMultiple can be read and written using a block tag with 3 elements.
trendLogMultiple-<objectAddress>.eventMessageTextsConfig |
Size |
3 elements |
B1: |
B2: |
<type> = 27 |
B3: |
B4: |
<property> = 352 |
3 elements |
Index |
Name |
Type |
0 |
elm00 |
A string value. |
1 |
elm01 |
A string value. |
2 |
elm02 |
A string value. |
