trendLogMultiple.ackedTransitions |
Conveys three flags that separately indicate the receipt of acknowledgements for TO-OFFNORMAL, TO-FAULT, and TO-NORMAL events.
Property ackedTransitions of object trendLogMultiple can be read and written using a block tag with 3 elements.
trendLogMultiple-<objectAddress>.ackedTransitions |
Size |
3 elements |
B1: |
B2: |
<type> = 27 |
B3: |
B4: |
<property> = 0 |
3 elements |
Index |
Name |
Type |
0 |
toOffnormal |
1 |
toFault |
2 |
toNormal |
