trendLog.covResubscriptionInterval |
Specifies the number of seconds between COV resubscriptions, provided that COV subscription is in effect.
Property covResubscriptionInterval of object trendLog can be read and written using a single IOTag.
trendLog-<objectAddress>.covResubscriptionInterval |
<type> = 20 |
<property> = 128 |
A 32-bit unsigned integer.
