timeValue.relinquishDefault |
The default value to be used for the presentValue property when all command priority values in the priorityArray property have a NULL value.
Property relinquishDefault of object timeValue can be read and written using a single IOTag.
timeValue-<objectAddress>.relinquishDefault |
<type> = 50 |
<property> = 104 |
A Date/Time value (only the Time part).
