timer.timerState |
Indicates the current state of the timer this object represents. To clear the timer, i.e. to request the timer to enter the IDLE state, a value of IDLE is written to this property.
Property timerState of object timer can be read and written using a single IOTag.
timer-<objectAddress>.timerState |
<type> = 31 |
<property> = 398 |
An integer representing one of the options of enumeration <BACnetTimerState>.
