timer.statusFlags |
Four boolean flags that indicate the general 'health' of an analog input.
Property statusFlags of object timer can be read and written using a block tag with 4 elements.
timer-<objectAddress>.statusFlags |
Size |
4 elements |
B1: |
B2: |
<type> = 31 |
B3: |
B4: |
<property> = 111 |
4 elements |
Index |
Name |
Type |
0 |
inAlarm |
1 |
fault |
2 |
overridden |
3 |
outOfService |
