timer.priorityForWriting |
Provides a priority to be used by the command priorization mechanism.
Property priorityForWriting of object timer can be read and written using a single IOTag.
timer-<objectAddress>.priorityForWriting |
<type> = 31 |
<property> = 88 |
A 32-bit unsigned integer.
