timer.outOfService |
Indicates weather (TRUE) or not (FALSE) the physical input that the object represents is not in service.
Property outOfService of object timer can be read and written using a single IOTag.
timer-<objectAddress>.outOfService |
<type> = 31 |
<property> = 81 |
