timer.lastStateChange |
Indicates the last transition the timer state machine performed.
Property lastStateChange of object timer can be read and written using a single IOTag.
timer-<objectAddress>.lastStateChange |
<type> = 31 |
<property> = 395 |
An integer representing one of the options of enumeration <BACnetTimerTransition>.
