timer.initialTimeout |
Indicates the initial timeout, in milliseconds, that was taken as initial duration to count down when the timer last transitioned to state RUNNING.
Property initialTimeout of object timer can be read and written using a single IOTag.
timer-<objectAddress>.initialTimeout |
<type> = 31 |
<property> = 394 |
A 32-bit unsigned integer.
