timer.eventTimeStamps
Conveys the times of the last TO_OFFNORMAL, TO_FAULT, and TO_NORMAL events. Timestamps of type Time or Date shall have X'FF' in each octet, and Sequence Number timestamps shall have the value 0 if no event of that type has ever occurred for the object.
Property eventTimeStamps of object timer can be read and written using a block tag with 3 elements.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
timer-<objectAddress>.eventTimeStamps
Size
3 elements
Numeric Parameters
Property
Value
B1:
<deviceAddress>
B2:
<type> = 31
B3:
<objectAddress>
B4:
<property> = 130
Size:
3 elements
Block Elements
Index
Name
Type
0
elm00
A Date, Integer, Null or String (Xml) value representing a timestamp in BACnet.
•A null value means the timestamp is empty/not set;
•A date/time value representing a precise date and time;
•An integer defining the timestamp sequence number;
•A character string containing an XML with a value of type <BACnetTimeStamp>.
1
elm01
2
elm02
