timer.defaultTimeout |
Specifies the default initial timeout, in milliseconds. This default timeout is used as the initial timeout when a value of TRUE is written to the Timer_Running property. The value of this property shall be within the supported range specified by the values of the Min_Pres_Value and Max_Pres_Value properties.
Property defaultTimeout of object timer can be read and written using a single IOTag.
timer-<objectAddress>.defaultTimeout |
<type> = 31 |
<property> = 393 |
A 32-bit unsigned integer.
