structuredView.nodeType |
Provides a general classification of the object in the hierarchy of objects. It is intended as a general suggestion to a client application about the contents of a Structured View object, and is not intended to convey an exact definition. Further refinement of classification is provided by the Node_Subtype property.
Property nodeType of object structuredView can be read and written using a single IOTag.
structuredView-<objectAddress>.nodeType |
<type> = 29 |
<property> = 208 |
An integer representing one of the options of enumeration <BACnetNodeType>.
