structuredView.defaultSubordinateRelationship |
Describes the default relationship to each member of the Subordinate_List, unless overridden by a member of the Subordinate_Relationships property. If this property is absent and the Subordinate_Relationships is also absent, the relationship to the subordinates is equal to UNKNOWN.
Property defaultSubordinateRelationship of object structuredView can be read and written using a single IOTag.
structuredView-<objectAddress>.defaultSubordinateRelationship |
<type> = 29 |
<property> = 490 |
An integer representing one of the options of enumeration <BACnetRelationship>.
