schedule.presentValue |
Indicates the current value of the object.
Property presentValue of object schedule can be read and written using a single IOTag.
schedule-<objectAddress>.presentValue |
<type> = 17 |
<property> = 85 |
A simple value type (Integer, Real, Date, String) or a string containing an XML representation of: Null, Boolean, Unsigned, INTEGER, REAL, Double, OctetString, CharacterString, BitString, Enumerated, Date, Time, BACnetObjectIdentifier.
