program.reasonForHalt |
Reflects the reason why the process was halted. 0 = normal, 1 = load failed, 2 = internal, 3 = program, 4 = other
Property reasonForHalt of object program can be read and written using a single IOTag.
program-<objectAddress>.reasonForHalt |
<type> = 16 |
<property> = 100 |
An integer representing one of the options of enumeration <BACnetProgramError>.
