program.programLocation |
String that may be used by the application program to indicate its location within the program code, for example, a line number or program label or section name.
Property programLocation of object program can be read and written using a single IOTag.
program-<objectAddress>.programLocation |
<type> = 16 |
<property> = 91 |
A string value.
