positiveIntegerValue.timeDelay |
Specifies the minimum period of time in seconds that the presentValue must remain outside the band defined by the highLimit and lowLimit properties before a TO_OFFNORMAL event is generated or within the same band, including the deadband property, before a TO_NORMAL event is generated.
Property timeDelay of object positiveIntegerValue can be read and written using a single IOTag.
positiveIntegerValue-<objectAddress>.timeDelay |
<type> = 48 |
<property> = 113 |
A 32-bit unsigned integer.
