positiveIntegerValue.minPresValue |
Indicates the lowest number in engineering units that can be reliably obtained for the presentValue property of this object.
Property minPresValue of object positiveIntegerValue can be read and written using a single IOTag.
positiveIntegerValue-<objectAddress>.minPresValue |
<type> = 48 |
<property> = 69 |
A 32-bit unsigned integer.
