positiveIntegerValue.maxPresValue |
Indicates the highest number in engineering units that can be reliably obtained for the presentValue property of this object.
Property maxPresValue of object positiveIntegerValue can be read and written using a single IOTag.
positiveIntegerValue-<objectAddress>.maxPresValue |
<type> = 48 |
<property> = 65 |
A 32-bit unsigned integer.
