octetstringValue.relinquishDefault |
The default value to be used for the presentValue property when all command priority values in the priorityArray property have a NULL value.
Property relinquishDefault of object octetstringValue can be read and written using a single IOTag.
octetstringValue-<objectAddress>.relinquishDefault |
<type> = 47 |
<property> = 104 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
