octetstringValue.presentValue |
Indicates the current value of the object.
Property presentValue of object octetstringValue can be read and written using a single IOTag.
octetstringValue-<objectAddress>.presentValue |
<type> = 47 |
<property> = 85 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
