notificationForwarder.processIdentifierFilter |
Used in the selection of event notification service requests that are to be forwarded by the object. When the Process Identifier parameter of a received event notification is the same as the value of the Process_Identifier_Filter property, or if the Process_Identifier_Filter property contains a NULL, then the notification will be accepted for forwarding by the Notification Forwarder object subject to the port, network and broadcast restrictions.
Property processIdentifierFilter of object notificationForwarder can be read and written using a single IOTag.
notificationForwarder-<objectAddress>.processIdentifierFilter |
<type> = 51 |
<property> = 361 |
•A 32-bit unsigned integer.
•A null/empty value.
