notificationForwarder.portFilter |
Enables or disables the forwarding of event notifications received on a particular network port. When an event notification is received on a port that is marked as disabled by this property, the Notification Forwarder object shall ignore that event notification.
Property portFilter of object notificationForwarder can be read and written using a single IOTag.
notificationForwarder-<objectAddress>.portFilter |
<type> = 51 |
<property> = 363 |
A character string containing an XML with a value of type <SequenceOfBACnetPortPermission>.
