notificationForwarder.localForwardingOnly |
Indicates whether (TRUE) or not (FALSE) the object is limited to forwarding notifications initiated from within the same device. If Local_Forwarding_Only has a value of FALSE, then the Notification Forwarder is capable of forwarding notifications for other devices.
Property localForwardingOnly of object notificationForwarder can be read and written using a single IOTag.
notificationForwarder-<objectAddress>.localForwardingOnly |
<type> = 51 |
<property> = 360 |
