notificationClass.ackRequired |
Conveys three separate flags that represent whether acknowledgement shall be required in notifications generated for TO-OFFNORMAL, TO-FAULT, and TO-NORMAL event transitions, respectively.
Property ackRequired of object notificationClass can be read and written using a block tag with 3 elements.
notificationClass-<objectAddress>.ackRequired |
Size |
3 elements |
B1: |
B2: |
<type> = 15 |
B3: |
B4: |
<property> = 1 |
3 elements |
Index |
Name |
Type |
0 |
toOffnormal |
1 |
toFault |
2 |
toNormal |
