networkSecurity.securityTimeWindow |
Specifies the security time window for the device in seconds. The recommended default value for this property is 180 (3 minutes). The property shall be restricted to the range 1 through 600.
Property securityTimeWindow of object networkSecurity can be read and written using a single IOTag.
networkSecurity-<objectAddress>.securityTimeWindow |
<type> = 38 |
<property> = 335 |
A 32-bit unsigned integer.
