networkSecurity.securityPduTimeout |
Specifies the length of time, in milliseconds, the device waits for a security response. For the application TSM to work correctly, this value should be configured to be less than the APDU_Segment_Timeout value in the Device object.
Property securityPduTimeout of object networkSecurity can be read and written using a single IOTag.
networkSecurity-<objectAddress>.securityPduTimeout |
<type> = 38 |
<property> = 334 |
A 16-bit integer value ranging from 0 to 65535.
