networkSecurity.lastKeyServer |
Specifies the device identifier and address of the last Key Server that successfully updated a security key in the device. If no Key Server has updated the keys sets in the device, the deviceidentifier field shall contain 4194303 in the instance part, the network-number field shall be 0, and the mac-address field shall be empty. This property is writable in order to allow a Key Server address to be provided to the secure device before it has received a Device-Master key. This allows the secure device to be directed to the Key Server in a legacy environment where globally broadcast Request-Key-Update messages will not be routed. A device may make this property read-only once a Device-Master key has been received.
Property lastKeyServer of object networkSecurity can be read and written using a block tag with 3 elements.
networkSecurity-<objectAddress>.lastKeyServer |
Size |
3 elements |
B1: |
B2: |
<type> = 38 |
B3: |
B4: |
<property> = 331 |
3 elements |
Index |
Name |
Type |
0 |
DeviceIdentifier |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345'). |
1 |
DeviceAddress_NetworkNumber |
A 16-bit integer value ranging from 0 to 65535. |
2 |
DeviceAddress_MacAddress |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A'). |
