networkSecurity.distributionKeyRevision |
Identifies the device's Distribution key revision. This property shall be 0 if the device does not have a Distribution key.
Property distributionKeyRevision of object networkSecurity can be read and written using a single IOTag.
networkSecurity-<objectAddress>.distributionKeyRevision |
<type> = 38 |
<property> = 328 |
An 8-bit integer value ranging from 0 to 255.
