networkSecurity.baseDeviceSecurityPolicy |
Specifies the minimum level of security that the device requires allowing client devices to know the level of security to use when communicating with the device. While devices may require higher security levels for some operations, this property shall be readable using the security level defined by this property.
Property baseDeviceSecurityPolicy of object networkSecurity can be read and written using a single IOTag.
networkSecurity-<objectAddress>.baseDeviceSecurityPolicy |
<type> = 38 |
<property> = 327 |
An integer representing one of the options of enumeration <BACnetSecurityLevel>.
