networkPort.slaveProxyEnable |
Indicates whether (TRUE) or not (FALSE) the device will perform Slave-Proxy functions for this port. This property shall be present and writable if the device is capable of performing the functions of a Slave-Proxy device on this port.
Property slaveProxyEnable of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.slaveProxyEnable |
<type> = 56 |
<property> = 172 |
