networkPort.protocolLevel |
Indicates whether the object represents a physical network interface (PHYSICAL), a non-BACnet protocol (PROTOCOL), the BACnet use of the protocol (BACNET_APPLICATION), or a non-BACnet use of the protocol (NON_BACNET_APPLICATION).
Property protocolLevel of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.protocolLevel |
<type> = 56 |
<property> = 482 |
An integer representing one of the options of enumeration <BACnetProtocolLevel>.
