networkPort.networkType |
Represents the type of network this Network Port object is representing. When the Protocol_Level is BACNET_APPLICATION, the Network_Type indicates the protocol over which BACnet is operating and implies that the requirements laid out in the appropriate clause are being met. For example, if the Network_Type is IPV4, then the port is operating as a BACnet/IP port.
Property networkType of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.networkType |
<type> = 56 |
<property> = 427 |
An integer representing one of the options of enumeration <BACnetNetworkType>.
