networkPort.networkInterfaceName |
Identifies the network interface hardware to which this network port is bound. For example, if Network_Type is IPV4, the value of this property identifies the Ethernet hardware interface that this network port is using to communicate.
Property networkInterfaceName of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.networkInterfaceName |
<type> = 56 |
<property> = 424 |
A string value.
