networkPort.maxMaster |
Specifies the highest possible address for master nodes, and shall be less than or equal to 127.
Property maxMaster of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.maxMaster |
<type> = 56 |
<property> = 64 |
An 8-bit integer value ranging from 0 to 255.
