networkPort.maxInfoFrames |
Specifies the maximum number of information frames the node may send before it must pass the token.
Property maxInfoFrames of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.maxInfoFrames |
<type> = 56 |
<property> = 63 |
An 8-bit integer value ranging from 0 to 255.
