networkPort.linkSpeedAutonegotiate |
Represents the auto negotiation setting of the network port. A value of TRUE indicates that the device automatically determines the speed of this network port. In this case, Link_Speed shall be read-only and indicate the determined speed, if available. A value of FALSE indicates that the link speed is determined by the value of the Link_Speed property.
Property linkSpeedAutonegotiate of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.linkSpeedAutonegotiate |
<type> = 56 |
<property> = 422 |
