networkPort.linkSpeed |
Represents the network communication rate as the number of bits per second. A value of 0 indicates an unknown communication rate.
Property linkSpeed of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.linkSpeed |
<type> = 56 |
<property> = 420 |
A 32-bit floating point number.
